Home | Reviews
Login  |  Register
Interbike 2007
Space Jump
The Space Jump fork has been in development for the past 3 years, constantly being refined to withstand the abuse of dirt jumping and every other terrain that a freeride hardtail could withstand. The super-stiff Magnesium lowers and 36mm stanchions are the necessary size to handle the abuse without sacrificing weight. The Space Jump comes with adjustable Air pre-load and adjustable hydraulic rebound for customization and easy service.
Weight: 5 lb 9 oz
Travel: 80mm or 100mm
Color: White, Black, or Raw
Stanchion size: 36mm
Axle to crown height(mm):465/485
MSRP: $299.00
Street/DJ
-Adjustable sealed hydraulic cartridge rebound.
- Steel coil sprung with different spring rates available.
-IS disc mounts and grease ports for easy maintenance.
-Comes with Air pre-load adjust and high-pressure air pump.
-20mm thru axle
<< Previous Next >>
Back to the RST booth
Contact Us  •   About Us  •   Terms of Use  •   Privacy Policy  •   Advertising
 MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
 PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
 AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
Copyright ©1996-2008 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
