| At Avid, we designed the Juicy Seven hydraulic disc brake to solve the problem of uneven lever engagement, and about 5,000 other problems you didn’t even know you had. Featuring a Tri-Align caliper positioning system, a rotor a ninja would use, the best caliper design in the business, foolproof lever adjustment and switch hitter levers. Its not IF you'll want to switch, its when. Available in 160,185 and 203mm rotors. |
