Home | Reviews
Login  |  Register
Interbike 2004
Preston FR
The Preston FR is all about short travel freeriding at it's finest. A tight responsive suspension that is there when you need it when things get rough, but also won't soak up your energy while flowing your favorite trails and dirt jumps. The Preston FR is quickly becoming a favorite of ours and our pro rider JS because of it's versatility.
Let's face it, sometimes large travel Freeride bikes are overkill for many trails and end up weighing you down, especially when you have to earn your trail by pedaling up. The Preston FR coupled with the amazing Romic Double Adjust rear shock provides the best of both worlds. The ability to be a super efficient pedaling bike as well as taking serious abuse that freeriders frequently take out on their bikes. Run it with 5 or 6" single crown forks with 20mm through axles for the ultimate versatility in a do everything freeride bike.
Then Preston FR comes standard with custom Dangerboy rockers with 4-5 inches of adjustable rear wheel travel. These rockers are specifically design for the Preston FR by Shant over at Dangerboy CNC and not only look amazing but provide a very stiff rear end. All pivots glide on sealed bearings for smooth maintenance free action.
NSMB.com reviews the Preston FR
"You're getting a high-quality frame from a company that truly believes it is producing a no-compromise product suited to a rider who enjoys the bold and burly, but also has the skills and range to appreciate a bike that excels at a wide range of tasks." - Richard Belson, NSMB.com
Frame Features:
-4-5" of rear travel
-7000 Series Heat Treated Aluminum frame
-Headtube gusset
-Custom Dangerboy CNC rocker arms
-Accepts 8" Rear Disc Brake Rotor
-Frame Weight (including rear shock): 8.5lbs.
-1 year warranty, Lifetime crash replacement
-Sizes: 17", 19"
Shock Features: Compression Dampening
Rebound Adjustment
Color: Gloss Silver, black anodized rocker arms, black decals
Build Specs: Front Derailleur: 34.9 clamp, top pull, Shimano M751
Bottom Bracket: 68mm x 113mm
Headset: Standard 1 1/8"
Seatpost: 30.4mm
Price: $959 US
How to Buy: To purchase a frame you can email us at info@transitionbikes.com and we will contact you or you can call us directly at (206) 226-0482 to place your order by phone.
<< Previous Next >>
Back to the Transition Bikes booth
Contact Us  •   About Us  •   Terms of Use  •   Privacy Policy  •   Advertising
 MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
 PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
 AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
Copyright ©1996-2009 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
