Home
Login  |  Register
Mavic Crossland UST
Average Rating 3.5/5
# of Reviews 10
MSRP $
Weight
More Products from Mavic
Description:
  • Front and rear axle: Steel
  • Rims material: 6106 Aluminum
  • Shape: Straight pull, round
  • Front and rear body: Aluminum
  • Bearing: QRM
Where To Buy
Chain Reaction Cycles
BlueSkyCycling
Wheel World
Cambria Bicycle Outfitters
Price Point
Other Ways To Shop
  • Buy and Sell the Crossland UST from our Classifieds.
  • Shop for Similar Products
    Nashbar
    Performance
    JensonUSA
    Submitted by D Thomas Lamourine a Weekend Warrior from Old Lyme
    Date Reviewed: April 30, 2008
    Favoriate Trail:Rocky point LI, NY
    Duration Product Used:Less than 1 month
    Price Paid: $109.00
    Purchased At:CBO
    Strengths:Light!!, stiff!!, smooth... OK... and look good too!!
    Weaknesses:none ...... so far
    Similar Products Used:Shimaro/ Sunrim
    Bike Setup:K2 Apache 5/ Sram x-9 drivetrain/Avid BB7 brakes... bla bla bla Very light bike!
    Bottom Line:SO far they are WAY better than the stock Shimaro/Sumrim cheapies that came on the bike. Much stiffer, truer, smoother running. Just got the rear.
    read all the complaints about these cracking. but they are XC rims. Not "All Mountain" and I'm guessing that most people who have had issues with them are younger and more All MTN riders, that ride a little harder then they where intended for, and expect these light weight wheels to be stronger.
    I'm a gezzer, (OK 40+) and ride more of a single track/dirt road type trails with little or no drops, so I'm guessing that I'm not going to have an issue ( I hope)
    Now they are replacing them with the crosstrail probably to get rid of some of the bad hype but if you can get a Crossland and ride less aggressive then I think you'll love them over normal cheaper wheels
    Value Rating:5Overall Rating:4
    Submitted by Mark a Racer from Wisconsin
    Date Reviewed: February 16, 2008
    Favoriate Trail:
    Duration Product Used:2 Years
    Price Paid: $
    Purchased At:
    Strengths:Strength, serviceability
    Weaknesses:Nothing so far.
    Similar Products Used:Custom wheels
    Bike Setup:Cannondale Scalpel
    Bottom Line:I am a clydesdale (250 lbs.) and race (16 times usually per year). I have not had any problems with these wheels what so ever. I have had to true them once at the end of last year.
    I run tubeless all the time and recommend it to anyone. I have used regular UST tires and have used regular tires with Stan's fluid. Either way works fine with these wheels. For UST tires you can mount them with a floor pump, but a air compressor works the best.
    I don't know what the other people were complaining about. I weigh 100 lbs. more than he does and ride very aggressively and never had a problem. So for the money you can't go wrong.
    BUY THESE WHEELS!!!
    Value Rating:5Overall Rating:5
    Submitted by dave a from boise
    Date Reviewed: December 5, 2007
    Favoriate Trail:
    Duration Product Used:More than 3 years
    Price Paid: $220.00
    Purchased At:performance
    Strengths:reliable,strong.
    Weaknesses:rim brake surface looks dweeb if you are useing disc.
    Bike Setup:2004 Ibex tropphy hardtail, 2006 Heckler.
    Bottom Line:I do not know what the hell you guys are talking about in regards to reliability, I have 2 sets of these wheels and have had absolutely no problem with them however I am quite religious about maintainence are youse knuckleheads? or do you work for some other wheel company?
    Submitted by Vibrato a Cross Country Rider from Silvis Illinois
    Date Reviewed: October 3, 2007
    Favoriate Trail:Any in Dupont
    Duration Product Used:1 Year
    Price Paid: $200.00
    Purchased At:Little Aydes, Pekin Il
    Strengths:Inexpensive, they look good
    Weaknesses:Axles!!!
    Similar Products Used:Stock WTB's, Shimano's
    Bike Setup:07' anthem, xt dual controls w/ hydro disks, external bearing crank, etc.
    Bottom Line:200.00 for the wheel SET, 50.00 to replace the rear axle. Now I've broken it twice!! If you're less than 150 pounds or never leave the ground, good wheels, if you're rough on a bike, you may not want these.
    Value Rating:2Overall Rating:2
    Submitted by Keith a Cross Country Rider from gainesville, ga
    Date Reviewed: August 21, 2007
    Favoriate Trail:bull mountain
    Duration Product Used:6 months
    Price Paid: $100.00
    Purchased At:ebay - rear wheel
    Strengths:UST, rims are fairly strong and stay true
    Weaknesses:Hub is complete crap, shims in freehub come loose, a ceramic bushing inside the freehub wears down and causes play in the freehub, causing shifting and cassette problems
    Similar Products Used:mavic crossmax (lasted longer than crossland) but too expensive to fix, xt hubs w/ rhynolites (indestructable)
    Bike Setup:jamis dragon, xtr, v-brakes, crossmax front (still going), xt/rhynolite rear
    Bottom Line:Buy only if you plan on replacing after around 600 miles of mtb. Mavic does not know how to make a serviceable, quality rear wheel. 1 time shame on you, 2 times shame on me. Never again will I buy mavic. xt/ rhynolites - $150 - 4500 miles and counting
    2 chilis for working well for 6 months.
    Value Rating:1Overall Rating:2
    Submitted by John a Cross Country Rider from Chandler, AZ, US
    Date Reviewed: May 9, 2007
    Favoriate Trail:South Mountain
    Price Paid: $220.00
    Purchased At:Price Point
    Strengths:Tubeless, relatively light and cheap
    Weaknesses:Rear hub needs periodic cleaning
    Similar Products Used:Shimano hubs with other mavic rims
    Bike Setup:Turner Burner, manitou minute 1:00, manitou 3 way swinger, shimano xt and xtr parts
    Bottom Line:This was a relatively good set of wheels for the first 2 years. I weight about 185 lbs and ride 3 to 4 times a week, aggressive XC. The rims stayed surprisingly true in that time. The rear hub would require cleaning every 7 to 8 months, but it was easy to take apart. I really liked the tubeless rims, just use a little Stans-no-tube and they worked great. At 2.5 years cracks developed near most of the spoke nipples of the rear rim. Then one nipple broke threw and tore the rim. That was it for the rear rim. The front rim is still going. I can't bring myself to buy another set knowing that they will be trashed in a couple of years. If you weight less, you may want to consider buying them.
    Value Rating:3Overall Rating:2
    Submitted by Seth a Cross Country Rider from Hanahan, SC,
    Date Reviewed: May 2, 2007
    Favoriate Trail:
    Price Paid: $213.00
    Purchased At:
    Strengths:Can run either disc or rim brakes. Never needs truing.
    Weaknesses:If using the supplied quick-release, will damage your fork's dropout. Can't get the quick-release tight enough, evenually comes loose, causes the dropout to rub against the hub.
    Bike Setup:
    Bottom Line:Upgrade the cheap quick-release skewer prior to using these wheels. After one year of use and not using better skewers, I'm looking at replacing the lower legs on my $600 fork. Lesson learned.
    Value Rating:5Overall Rating:2
    Submitted by gary a Cross Country Rider from arkham, ma
    Date Reviewed: April 15, 2007
    Favoriate Trail:
    Price Paid: $
    Purchased At:lbs
    Strengths:perform well, rugged, inexpensive, ust, look good
    Weaknesses:none
    Similar Products Used:numerous other stuff, xt hubs on different rims, hope xc on 717's
    Bike Setup:i now have these on 2 bikes, a non stock giant vt and a santa cruz superlight
    Bottom Line:i ride year round day or night and wanted to try ust, fixing flats on a cold winter night or mosquito infested bottomlands was getting old, tight budget,so i got these on the advice of my mechanic at a local bike shop. i'm well over a thousand miles on the first set and only needed a minor truing once on the front wheel. ride weirwolfs with a little stans, the wheels don't really feel all that heavy, ride alot of rocky stuff and my rims always look it, these have held up well, still roll smooth and i haven't flatted once. i don't know why these aren't more popular than they are, i consider these a great buy.
    Submitted by Richard Cranium a Weekend Warrior from Austin, TX, USA
    Date Reviewed: April 14, 2007
    Favoriate Trail:Walnut Creek Park
    Price Paid: $220.00
    Purchased At:LBS
    Strengths:Extremely strong & durable stays true no matter what you roll it over, jump over, drop off's etc... Straight pull spokes, super smooth rolling hubs, great looking and the ability to go tubeless at a super cheap price.
    Weaknesses:none than I can find
    Similar Products Used:Handbuilt Mavic 819's with XT hubs, Mavic 317's with DT Cerit hubs, Sun Rhynolite XL's....
    Bike Setup:Giant Trance 1 & Giant XTC
    Bottom Line:I am a clydesdale (6'2" & 240 lbs) and have had issues with everyone other wheelset I have ever ridden, warped/bent rims, continually having to true wheelsets etc...
    While picking up a wheelset from my LBS after they trued them (again) my most trusted mechanic recommended that I try the Mavic Crossland - best money I ever spent on my bikes. They look great, smooth.......... rolling hubs and in the past year and 800 trail miles later I have not had any issues, no more trips to get this wheelset trued ! This wheelset is bomb proof !!!!!!!!
    Submitted by Tedroy a Weekend Warrior from Pasadena
    Date Reviewed: April 4, 2007
    Favoriate Trail:Still lookin'
    Price Paid: $200.00
    Purchased At:supergo
    Strengths:Cheap & strong, UST, cool hubs, straight pull spokes, OK, they're a little heavy 'cause they have V-Brake surfaces, but c'mon for 2 bills (on sale) waddya want? The tubeless thing really makes sense for me 'cause I live in goatheadville!
    Weaknesses:Heavyish, While the UST valve stems are removeable the cores are not, so you have to bust the seal on the tire's bead to add / remove sealant.
    Similar Products Used:Mavic Crossmarks
    Bike Setup:04' Turner Burner, XR rockers, RP23, RS Reba W/U-Turn, poploc,
    and beer/intercooler hyperventilator!
    Bottom Line:These rims have treated me real well. No trueing needed after 2 years. UST feature holds air just fine. Mounting UST tires is do-able with a standard floor pump, but the local gas station compressor is a better option. There are cheaper wheels and super cool mega-xpensive hyper race wheels but these fit the bill for me. I ain't racing anybody but myself so the heavy wheels just mean I'm gettin' a better workout than weight-weenie boy. Also, the straight-pull spokes aren't so proprietary (like the new mavics) that if I broke one, I could probably find one in LA somewhere!
    Value Rating:3Overall Rating:3
    What's New
    » Sea Otter Classic - Race and Cycling Festival
    New products, race info, videos and more!»
    You need Flash Player 8 (or higher) and JavaScript enabled to view this content
    » Michelin Tire Giveaway Contest!
    Enter to Win a FREE Set of the Latest All Mountain Reinforced Tires from Michelin»
    » Buy Mtbr Jerseys
    Click here to view or buy the jersey and shorts.  Support Mtbr.com and order your set today.
    View or buy
    Mtbr Swag here»
    Latest Articles and Reviews:
    Quick Poll
    (sponsored by Rocky Mountain Bicycles)
    Have you ever broken a bone due to a bike crash?
      yes
      no
      no, but came really close to it
    Photo Caption Contest
    (sponsored by Maxxis)
    Enter here
    Contact Us  •   About Us  •   Terms of Use  •   Privacy Policy  •   Advertising
     MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
     PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
     AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
    Copyright ©1996-2008 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
